Thread: Question on pH testing
    Often when you add a number of gallons of chlorine (or bleach) the pH test becomes unreliable (the indicator turns red) suggesting a falsely alkaline pH.
    This week my kid may have put too much chlorine in the water. The chlorine level is testing really high. Okay fine. Now when I test the pH, the solution turns red. But how do I know if the pH is really alkaline or not?
    35,000 gal pool, Pebble-Tec, Pentair VF pump, DE filter, Aqua Rite SWG, Pentair Minimax Heater in Southern California
    30,421
    Re: Question on pH testing
    What is "really high"?
    Once FC goes above 10 ppm, the pH will read falsely high and can only be considered accurate when the FC falls back below 10 ppm.
    Test and dose carefully.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    One FC goes above 10 ppm, the pH will read falsely high and can only be considered accurate when the FC falls back below 10 ppm.
    a +1 on this.
    Essential Links:
    38,290
    Are you using one of the recommended test kits with the FAS-DPD chlorine test? Test and Report the FC.
    I have the recommended test kit but I often use the "simple" test kit in a hurry. For ph you put in a dro of thiosulfate then 5 drops of red indicator solution.
    38,290
    Which recommended test kit? What pH test requires a drop of a second reagent before the red r14/r4? What is your FC?
