Results 1 to 8 of 8
Thread: New owner with jet issues. Please help.
    Recently got my first hot tub and have came to find out I filled up the tub wrong. Dont really know too much about hot tubs. It is a two pump system one pump is running great the other is not. I have bleed out air from the system with no results. If I run what is working and turn the valve on top of the filter cap air still comes out. Do I need to keep letting air out or what should I do next. Please help I have looked on here for hours trying to find something to help me out.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: New owner with jet issues. Please help.
    Is this a new hot tub? Did it come with a manual? Can you find the manual online? We found ours and downloaded it to keep for quick reference. It does advise to fill the tub through the filter area to avoid air in the lines.
    It's used and I haven't found a brand name on the tub. Is there a way of figuring out the brand by there being specific parts or features? I'm starting to think one of the pumps is frozen. It clicks on humms clicks off then will humm again.
    Jan 2012
    7,367
    If you open up the access panel perhaps you will find something with the manufacturer's name?
    Just for reference, my hot tub dealer services hot tubs for $80/hour labor. If you can't figure this out, perhaps having someone give it a once over and diagnose it would be helpful, and if you're handy you can do the work yourself. Just a thought...
    I've opened the panel and there is nothing. It has one waterway 2hp that does the filtration heating and some jets. Then it has a 6hp waterway pump that runs the rest of the jets which is the one that won't turn over. There is one plaque on the outside of the panel that just says 4699.
    May 2013
    Cyprus
    159
    Is their a control panel on the top of the tub and it should be marked jets temp exctsetra usually 4 buttons. Also power off the tub and try manualy turning the pump , then power on and try again.
    Living in Cyprus
    Still enjoying life
    Yes there is control panel with 4 buttons. Whats the best way to try and manually turn the pump? I've tried sticking a screwdriver in and rotating it but there really is not enough room. Pump butts right up to a pipe.
    May 2013
    Cyprus
    159
    OK the fan at the rear of the motor try pushing a screwdriver downwards or you could remove the water supply pipe their should be a lock off valve and turn the vane. if you manage to turn the motor and it still does not run then the start capacitor may need to be checked. If the tub has been oos for a period of time then the seal between the motor and the pump might leak this is not a catastrophe but it will have to be repaired. A photo would be nice so we can get a better idea. On the control panel their is sometimes a model name. Good luck.
    Living in Cyprus
    Still enjoying life
