Results 1 to 11 of 11
Thread: Temp limitations on Robots
    30,419
    By Monday, my pool water temp will be around 42-45 degrees. The documentation (it's horrible) for my Dolphin Premier lists no temp limitations for operating the robot in water that cold.
    Anybody, regardless of brand, have a manufacturer's limitation for a robot?
    Mar 2010
    122
    Re: Temp limitations on Robots
    On dolphins and the Hayward tiger sharks I believe it's anything under 49 F. They won't climb the walls or really steep slopes.
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    38,275
    Something I had not considered. What exactly could be damaged by running in cold water? (although I doubt my water ever gets that cold)
    The manuals show 41 F as the low temperature limit.
    Support the site
    30,419
    Quote Originally Posted by JamesW
    Well, shoot, I might have a couple of degrees to spare!
    I doubt they have a cold temp sensing limiter but I imagine the increased resistance of all the cold parts might load up the motors too much and cause them to shut off.......we'll see.
    The 41f might be for storage. They show 54 f as a lower limit for "optimal" operation. I can't find a definite lower operating temperature.
    Support the site
    30,419
    I ran it yesterday......probably around 50 degree temp......it appeared a bit sluggish but it may have been my imagination.
    Mar 2010
    122
    As far as I know it just won't climb the walls under 50. Should operate fine other then that
    Sep 2013
    Buffalo,NY
    64
    I have a Polaris 9300 I just got end of this years season. Pool wasn't finished till early Nov and it appeared to work ok in 45 degree water.
    Daren
    DRB
    16x32 20K IG vinyl, Hayward Pro Grid DE4820 w/ 2-speed 1.5HP Hayward TriStar pump with a .75HP impeller installed, AutoPilot Digg-220
    Jan 2018
    West Vancouver
    1
    Quote Originally Posted by drb View Post
    Daren
    My Hayward Tiger Shark worked fine for 5 years here in West Vancouver where the water drops below 40 degrees in the winter. I have a heater that kicks in and keeps the water from actually freezing when it gets really cold. This strategy has worked fine for years - the water is COLD but the pool stays stable, clean and I don't have to pay for draining and filling etc. But this year the treads on the Bot cracked and broke. I replaced them and they broke again less than a month later. I have replaced them now three times already in 6 months. I suspected at first that the replacement treads were possibly already old when i received them - maybe the rubber material gets brittle with age - but the most recent set are from a completely different lot number. Maybe they changed the formulation of the rubber and the new ones are not as good or... and this is why I am posting here - maybe they are not as resistant to cold as the originals? I can't think of what else it might be. Anyone else have similar problems?
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,335
    Welcome to the forum!
    Is this a regular pool heater? Pool heaters are NOT designed for this purpose. They are only to be used when the water being heated is above 68F for a pool volume. For a Spa, they can handle that small amount of water being colder as it warms above that level quickly.
    The destruction of the firebox in a pool heater doing what you are describing is typically fairly quick.
    Can you add a signature? See Pool School - Getting Started
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
