Thread: Melody SAVI LED Lights Problems
    Problems 1 - I have two Melody LED lights in the same circuit and every once in a while turn off for 1-2 seconds and then come back on. Please provide some ideas as what to troubleshoot as I have googled around to no avail.
    Problem 2 - Is there a way to make them keep memory of the last setting. I'm tired of syncing them to come back to un-synced lights.
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Melody SAVI LED Lights Problems
    I'm no help asandova, but I can say welcome to TFP!
    Perhaps someone has the answer, but I don't recall hearing of these before. Good luck!
    Essential Links:
    Jan 2011
    Richmond, Texas
    595
    With the power off I would check all of the connections. Wire nut and such. I had something very similar to this happen to my central AC and it ended up being a bad cut off (regular wall switch) switch in the attic. It had melted where the wire connected to the switch. The wire would get hot and move just enough to shut down for a few seconds and then come back on. I bet fixing #1 will take care of your second problem as well.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Thanks for the welcome and the tips, will be trying this coming weekend as I spend this weekend doing major maintenance (cleaning DE Filter (1st time) and adjusting salt level).
    Jan 2011
    Richmond, Texas
    595
    Let us know if that works.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Are you waiting 10-15 seconds after you turn the light(s) on? The lights will come on white, then revert to the color they were in when power was switched off. Syncing the lights is kinda involved (several steps) and may appear to be synchronized when they really aren't. Do you have the syncing instructions?
    http://www.nextstepproduct.com/SAVI/pdf ... 020712.pdf
    The on off problem may be a problem with the light, or X-former connections. I encourage you to call Next-step/SAVI about this.
    407.855.5630
    They are in Florida.
    Factory Warranty Station for:
