Thread: Best Pool Cover Pump
    I closed my pool for the first time this year. Live in West TN so quite a bit of rain but not much snow or ice. Have a 40x20 (pool is 16x40) heavy duty mesh cover secured with water bags. Trying to determine the best cover pump as it's pouring today and now have a few inches of rain sagging it down (didn't know anything about this - my roommate forgot to mention my pool closer said needed one). Local pool store recommends a Little Giant (for $250) but read reviews on Amazon and they seem fairly iffy. Anyone have a brand they recommend - or is manually siphoning preferred? Any advice on setting up a particular way? Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Best Pool Cover Pump
    Welcome to TFP scubaks!
    Someone will likely weigh in with experience, but sorry I can't help you on it. Enjoy the forums.
    Essential Links:
    Jun 2007
    New Jersey
    653
    Went through two Little Giants my first two years. I do not recommend.
    I am on my second Rule pump (replaced under warranty) in seven years. I do recommend. The circuit protection system on the Rule makes it just superior to the LG. So is the 3-year warranty.
    I have a solid cover so can't help you on set up.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
