Thread: How to remove this eyeball fitting?
    Dec 2013
    New Zealand
    4
    Hope someone can help, any idea's on how to remove this eyeball fitting? I'm wondering if there's a tool for the job as it looks like there are 2 holes top & bottom. The reason I want to remove it is to fit a slimebag to collect the fine stuff that goes right through the filter.. If it can't be removed easily, I was thinking of rigging up a hose to the backwash waste pipe and the other end to the slimebag in the pool. The idea being I could then vacuum to waste through the slimebag and save the water at the same time. Does this sound feasible?
    Cheers Martyn
    32ft x 13ft In-ground Vinyl pool, 14500 gallons, Hurlcon RX280 sand filter (replaced with glass media), Hurlcon CX 240 Pump (63 Gallons per minute) 15kw heat pump, Solar Pool Cover.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: How to remove this eyeball fitting?
    There are several styles, most simply unscrew, others are push on, etc.
    30,403
    Just a little off the subject, but if visible debris is passing through your filter, there is a problem with your filter.
    Secondly, what many people assume is debris returning to the pool is actually dead algae settling to the pool floor.
