Thread: Aqualink RS6 Freeze Protection
    Jul 2013
    Carrollton, TX
    40
    I have an aqualink RS6 to control my pool and spa. Right now I have the filter pump and spa set to run with freeze protect. The problem is that the 3 way valve will only circulate the pool or spa but not both at the same time. How do I circulate water in both the spa and pool O the pipes don't freeze?
    14,000 gal IG + spa, DE Filter, 400k BTU heater, Polaris 280, Aqualink RS6, TF-100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Aqualink RS6 Freeze Protection
    This depends on the type of 3 way valve you have, and how it is installed, if your lucky you much just be able to manually set it half way between the two positions and get flow to both. Assuming you have an actuator connector to the valve read the instructions for it on how to manually operate the valve, this will often involve loosening a knob and pulling out on the handle while turning, or similar
    Jul 2013
    Carrollton, TX
    40
    I found the answer. The aqualink changes between the pool and spa every 30 minutes.
