Thread: Black grout for waterline irridescent glass tile
    Dec 2013
    Vancouver, BC. Canada
    4
    Hello new friends! I'm in the final stages of pool completion, currently I have all tiles in place (glass irridescent mosaic, also irridescent subway tile) for waterline & benches etc. however the grout suggested by our pool contractor, that he has been using for many years on countless pools with good reasoning as to why this product is the best choice. eg. it's able to be re- grouted also cleaned via diluted acid wash. Q. The grout color is black (witch he has not used a great deal in the past) my concern is if washed with acid could it bleed down into the plaster thus staining it. the product is also a concrete base. without recomending to apply any sealant, do to pool chemical effects to sealants. anyway can anyone suggest a suitable grout for the color black with the best resistance to pool water etc.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Black grout for waterline irridescent glass tile
    Welcome to TFP!
    If I were going to use black grout (not sure I would.....), it would be epoxy. I think you're right that with normal grout the dye will bleed, and it will not be a nice black for very long.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I really don't know the correct answer to this, but I do know that black grout is very commonly used for the installation of mosaics.
    Welcome to TFP! Hope you enjoy the forums.
    Essential Links:
    30,432
    I have no idea as to the longevity of black grout.
    I would add that many, many pools develop a white line at the water level from calcium. Yours is very likely to do that and will require a LOT of cleaning if the grout is black.
    Dec 2013
    4
    Using a concrete based grout, for waterline tile (if any, what type of sealant will do the job?)
    30,432
    No sealant necessary.
