Thread: Pump control
    Aug 2009
    Flower Mound/Texas
    41
    Pump control
    I have an Intermatic Multi purpose control mode # P1353ME that is part of my system. When I was starting to winterize my system, I noticed that I got no readings from my SWG and that the power light was out. I turned off the power and restarted, but no effect. I checked the wires from the above mentioned control board to the SWG board and found that the was no power coming from the Intermatic control; however, the pumps did function. There doesn't appear to be any defect in the wiring that I can see. There are places behind the board in the Intermatic control that I can't see. Has anyone take this type of control apart? Any advice on how I might fix this?
    Thanks
    Charlie
    18,000 gal SWG, pebble tech, Jandy filter, Jandy Aquapure
    Flower Mound, Texas
    22,537
    Re: Pump control
    How is the timer programmed?
    Is it running freeze protection? If so it only powers in the pump.
