Results 1 to 10 of 10
Thread: Books?
    Nov 2013
    Orlando, FL
    29
    Books?
    Are there any "swimming pools for dummy's" type books out there anyone would recommend? In getting overwhelmed with equipment choices for my new pool build. Information is power...
    Pool TBD..
    IG gunite, probably SWG, solar heat
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: Books?
    Check out Pool School. There are a few articles on this topic. What questions do you have?
    Nov 2013
    Orlando, FL
    29
    Re: Books?
    Too many to list! Pool school was far too basic; there's not even a discussion of pros and cons of various pump options.
    I'm pretty sold on solar heat, but need some advice on DIY and brand specific pros and cons. The systems seem easy to DIY, except I'm not sure how to ensure I'm screwing into rafters.
    I'm also sold on salt water generator. Just need some brand specific pros and cons.
    All that said, in other endeavors I've really liked reading how to books to get a handle on a subject. They're no replacement for experience, but a good place to start...
    Pool TBD..
    38,245
    Re: Books?
    I am not aware of any books that will provide what you are looking for.
    But, there is a lot of information is past threads if you search for it.
    If you ask specific questions ... no matter how many ... then you will get specific answers. BUT, you may be getting too picky. As long as you stick with any of the major brands, pumps, filters, SWG, etc are pretty comparable and often there is no "best" just personal preference.
    Here are a couple tidbits that may or may not help:
    - Raypac gas heaters seem to have a good rep here
    - Pentair SWGs are limited to 20% increments ... unless you have one of their automation systems and then you get better control
    - If your electricity is relatively cheap and you do not need a lot of varying water flow rates, often a 2-speem pumps makes more sense than a VS pump
    There are just a lot of "it depends" answers to many questions when there is not enough information.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Books?
    Quote Originally Posted by Beer tunnel
    Definition of Experience - What is learned just AFTER you needed it the most !!
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Books?
    If there is/are a book(s) out there you'll find more information here than in any two of them combined. Good forums are plentiful in terms of information from all directions and this is the best pool forum on the net. If you look around and ask enough questions, you will surely find what you are looking for.
    Essential Links:
    Nov 2013
    Orlando, FL
    29
    Re: Books?
    Are there 2-speed pumps that are more efficient than others? In other words, VS or 2-speed are the categories, is there much variation within the category or are they all pretty close? I read something about the design of the motors being a factor...
    Pool TBD..
    38,245
    Re: Books?
    The electrical costs are really a function of the amount of water moved. All pumps with the same HP rating are not equal as some are designed to move less water. For example the Superflo lines of pumps is smaller than the Whisperflo line of pumps from Pentair.
    Every pump has a performance curve and if the curves are the same then the pump is basically the same.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Books?
    I will only add one more thing. You mention experience, and that is what you find in forums. There are already people talking about it, and dealing with it who have had the experience, and shared that info in the forums. If you so some reading, you can find lots of variation from real world use from many people versus the opinions and experience of one author.
    Essential Links:
    Jun 2013
    SpringHill FL
    415
    Re: Books?
    I agree type your questions into the search bar theres a great chance you will find the topic discussed in several threads. If you dont well then start typing individual questions lol. We love posts!!
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
