Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Pool plumbing under or beside the pool
    Oct 2013
    North of Dallas, TX
    7
    We are still comparing builders for our pool and wanted to get some input on the plumbing.
    Most of the pool builders north of Dallas put their plumbing beside the pool, I've got one builder who puts it under the pool. Which makes me wonder if beside the pool is better.
    Thoughts/opinions?
    22,000 AG, Jandy LRZ 400k BTU, Jandy FHPM1.0 FloPro 1HP SS (water features), Jandy ePump 2.0 (pool/spa), Jandy DEV60
    Nov 2011
    Moberly,MO
    1,010
    Re: Pool plumbing under or beside the pool
    I would think as a builder I would want it beside not under. If it ever leaks beside is much easier to repair. That is just my two cents worth.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Under the pool? The plumbing just goes where the end up laying the decking around the pool.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    mas985's Avatar
    Pleasanton, CA
    11,741
    Are you talking about having a main drain on the pool bottom which would require a pipe to pump?
    Or perhaps one of the builders is suggesting an in-floor cleaning system which also requires pipes under the pool as well?
    Pool plumbing can be properly designed without either of those things which would be my suggestion. Keep it simple and easy to repair which will make it less of headache in the future.
    Mark
    Oct 2013
    North of Dallas, TX
    7
    All the plumbing going under vs beside.
    mas985's Avatar
    Pleasanton, CA
    11,741
    What kind of pool is this (AG, IG, Gunite, Vinyl, Fiberglass) and why do they want to put the plumbing under the pool?
    There is no reason that I can think of to put ALL the plumbing under a pool and many reasons not to.
    Mark
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    I am guessing I know the PB you are talking to. I am considering them also, and this is also one of my concerns about them.
    Their argument is that the lines are run more directly (instead of snaking around the pool), and that it guards plumbing run around the pool from getting damaged by digging, roots, etc. I just don't like that they choose to do it differently than almost everyone else.
    Build Complete! : 111ft pool + 8.5x5.5ft spa (12" raised), ~22k gallons, Shotcrete, Stonescapes MiniPebble (Aqua Blue), 3 scuppers, 3 bubblers, Large Tanning Ledge, Long Bench, Pentair: Intelliflow 3050 VS, 1.5HP WhisperFlow (scuppers), Quad 100 DE filter, MasterTemp 400k, IC60 SWG, Intellichem+Acid Tank, 2HP Silencer Blower, travertine decking (~680ft2), dry stack flagstone raised wall / spa spillway
    Oct 2013
    North of Dallas, TX
    7
    gunite in ground.
    Nov 2011
    Moberly,MO
    1,010
    Gunite inground as a builder there is no way that I would put the plumbing under the shell in my local area. That being said where you live you may not deal with freeze and thaw, but I do just to much risk of damage to it. If it is buried alongside of the pool most generally anyone who is going to dig around a pool knows that plumbing is buried close by. Not sure I get his thinking, I wouldn't even recommend it on a vinyl lined pool. If you ever have to access it that will be extremely expensive to fix.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    plumbing under the pool, except for drain and in floor cleaning is just crazy thinking... it is not logical in the least to do that.
    Divin Dave,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Wow save $20 in PVC vs spend $20,000 if a line breaks, if it were me I would run, not walk away from that one. Note I have experienced 2 underground pipe breaks in the 30+ year history of my pool, one a random joint failure after about 20 years, the other an corner elbow fitting that blew out after about 30 years.
    Ike
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    The odd thing is this is a very well-respected PB in this area. They pitch this method as being superior, though you never know if they are really being up-front about things.
    I wouldn't necessarily say its a bad thing. Most of the plumbing will be encased in gunite. With the soils in north Texas, you will be much more likely to have a pipe failure outside the gunite.
    Now in the extremely rare case that there is a failure, it's much more difficult to get to the plumbing. Most of us have a significant amount of plumbing in our house foundations and that doesn't stop us from purchasing our homes.
    The direct route method is definitely a cheaper route, but RBS is also going to give you a better price. They are a volume builder with an in house plumbing crew.
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    It is just surprising to me, as PVC is not THAT expensive. If they thought it was an issue, they likely wouldn't do it. But, if the practice causes done people to shy away from them because they are different than virtually everyone else, I would think they would stop doing it this way. So, it leads me to believe they may actually see benefit in that method of plumbing.
    It's more so that they don't see any issues with the method. They've been doing it this way for a long time and they build 600 pools a year. They also include a 10 yr warranty on the plumbing.
    It's no doubt quicker and cheaper for them. It may not be everyone's preferred method, but certainly not a reason to walk away from a deal.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    I don't think they warranty their plumbing for 10 yrs. I think it is covered under the 1yr portion of their warranty. I believe only the structure (no leaks) is covered for 10yrs.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    Lifetime on the structure, rather.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    Quote Originally Posted by bhargraves
    I just spoke with them, and they indeed do cover their plumbing for 10yrs. My mistake!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What about at 15 or 20 years....
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,741
    Warranties are only as good as long as the PB stays in business and if the PB keeps building pools that way, it won't be for long.
    Mark
