Thread: Pentair intelliflow and whisperflow share the same wet end?
    Jul 2012
    Austin, TX
    75
    I have a Whisperflow right now. Just wonder if I can swamp in/out the pumps without re-plumping inlet and outlet connections. Thanks.
    Lazy-L shaped pool and a spa. 22.5k gallons. Pentair VS pump. Pentair cartridge filter CCP520. STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Pebble sheen (blue granite) Wooden deck.
    38,489
    Re: Pentair intelliflow and whisperflow share the same wet e
    Yes the wet end is the same, so the pipe should line up. But, they screw into the pump, so you will still have to cut the pipes to be able to install the new pump, unless you already installed union fittings.
    mas985's Avatar
    Pleasanton, CA
    11,741
    You could just replace the Whisperflo motor/impeller with the Intelliflo motor/impeller + drive and leave the Whisperflo wet end in place so you don't have to cut any plumbing.
    Mark
    Nov 2011
    Moberly,MO
    1,010
    Just dont try to swap in an XF the housings are just a little different
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
