Thread: Pipe should i see cement or sealer
    Hi Guys,
    Basic question I think but I am not sure of the difference.
    I had to replace a ball valve and now when I turn on the pump the pressure in the pipe by the ball valve causes the pipe to seperate and spew water.
    Question. Do I need pipe sealer or the cement ?
    22,553
    Re: Pipe should i see cement or sealer
    If it's a slip joint (which I'm pretty sure that it is) you need cement. Sealant is for threaded connections.
    Its threaded . Thank you Sir. How do should I wait before starting the pump ?
    Jun 2013
    SpringHill FL
    415
    Threaded use teflon tape or pvc rated "pipe dope". Its an instant fix once your screwed in your good to go
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    22,553
    It's very odd for a threaded connection to separate even without the sealant on it.
    It sounds like the pipe might be cracked. Can you post a picture?
    Support the site
