Thread: Pillow questions
    May 2013
    CT
    17
    Pillow questions
    Is it really necessary to have a pillow under the cover?
    I have one now but it seems like every time it rains or snows
    everything gathers unevenly on one side of the cover which
    in turn puts excessive pressure on the opposite side of the
    cover.
    Should I just get rid of it all together?
    15600 AG
    Filter Cartridge
    Waterway HI-FLO 48 2 Speed
    HI-250 GPM,LOW-144 GPM
    BBB,Leslie DPD Tester
    blackcats's Avatar
    Mar 2010
    CT
    19
    Re: Pillow questions
    It's not necessary. The first year I closed my pool, my pillow had a slow leak and deflated shortly after. I haven't used one since. I drain water from the cover as usual and leave a little on top to help keep the cover from cupcaking during high winds. Plus it just looks better!
    18' Sharkline Matrix, 2 speed pump, cartridge filter, 4x20 Fafco Solar Bear panel, AquaTrol SWG, Pool Rover S240
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Pillows don't really do much. Your pool won't explode or anything without one. I would recommend just putting a rule auto pump in the middle of your cover and forget it until you open the pool.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
