Thread: Using old acid ok?
    Mar 2009
    Charlotte, NC
    539
    Using old acid ok?
    I have some older dry acid from Leslie's; it is probably rockhard, haven't opened up it feels that way. I assume it is still okay to try to use it/ it has kept its potency reasonably well? I will just chip it up into pieces and the conservative/undershoot, and where appropriate protective clothing and eyeglasses
    thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Using old acid ok?
    If the plastic pail isn't too dry rotted you can always drop the pail on the ground a few times to loosen the dry acid. Should be fine to use.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would cut my losses, get rid of it and not hassle with chopping or putting it in. How are you planning on keeping it from going to the bottom if it dissolves slowly?
    Essential Links:
