Thread: Hello from Omaha
    Nov 2013
    Omaha
    30
    Hello from Omaha
    Hello! We are thinking of building our first pool next year. Anyone have experience in working with any pool builders in Omaha, NE that they could recommend we talk to?
    20k Gallon IG Vinyl Pool - 19 x 34 Rectangle - 3ft to 6ft depths
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hello from Omaha
    No recommendations from the east coast, but welcome to the forum
    You're done SLAMing when:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP ! Enjoy the forum.
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum. Someone should come along soon from eastern NE. In the meantime, it might be worth your while to check out the Under Construction forum. You may find members from your area that have had a new pool build within the last year or so.
    Nov 2013
    Omaha
    30
    Thanks BoDarville - I've been reading through some of the threads and am learning a lot. Next year with the pool build should be fun!
