Thread: LO alert on new heater.
    Jun 2012
    St Pete FL
    45
    So have a 20,000 gal pebble tec finish pool and spa with paper filter that had a new Hayward heater installed. Since installing it the heater starts, runs and after 10 minutes or so shuts off and says LO. Service light also comes on. Told by Pinch a Penny (who did install) it may be a bad filter and to bypass filter and see if it still does that. Only way I know to bypass filter is to take filter out of housing and turn pump back on. Is this correct or is there something else that should be done to bypass it? The filter is not brand new but it is new enough it should not be a problem.
    I took filter out of housing turned pump back on and LO alert came back on again after some time. Also does it when you switch from pool to spa.
    Help, opinions and or suggestions.
    Thanks.
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    Mar 2013
    Houston, TX
    14
    Re: LO alert on new heater.
    Is this a hayward universal h-series heater? I don't see it in your signature, but if it is "LO" means low flow. The heater isn't getting enough flow from your pump. If you have a two speed or variable speed pump try putting the pump in higher speeds. Then run the heater again and let it clear the error. For me, I needed about 1750 rpm on my ecostar otherwise the "LO" would trip on my heater after a couple minutes.
    18,000 gallon IG Gunite pool. White Pebblesheen. Flagstone Coping. 9' diameter level spa. 430sf Hayward Cartridge Filter. 2.5hp Hayward Ecostar VSP for filter. 1hp Hayward Super II Pump for waterwall. 400k BTU Hayward Universal H-Series natural gas heater. Ozonator (it was free). Hayward Prologic PS8 Controller.
    Jun 2012
    St Pete FL
    45
    Yes it is a Hayward heater and I figured it was low flow of water to the system. I do not believe it is a variable speed heater. How do I know that?
    Not in my signature because it is a neighbor across the street that moved to San Fran and I am trying to maintain the pool for him while they are gone and renting the house!!! It has become quite a chore and trying to be patient and not throw in the towel!!!
    Mar 2013
    Houston, TX
    14
    Quote Originally Posted by lilpam14
    Not the heater, but the pump that pushes the water through the filter to the heater. What is the model of the pump? If you don't know, you can take a picture of the pump label and post it here.
