Thread: Best tester to get?
    Best tester to get?
    We are moving into a house with a concrete pool. What is the best (budget)tester to get to tell the right numbers? It is about 16,000 gallons I think and kindney shaped. I would post a pic but do not know if that is ok. It looks a litte green but all we have right now is test strips that do not tell numbers. ANY help would be great!! Thanks!
    In Construction:
    425 SF Free form (aprox 18 x 23) IG Gunite
    7ft spa with spill over
    1.5 HP Jandy Pump
    1400 Aquapure Jandy SWG
    AE2500 Jandy Heatpump
    Re: Best tester to get?
    Sorry I did not see you could post pictures. I am new ....that's why any help is great!! thanks again
    http://tinyurl.com/5low7j
    In Construction:
    1.5 HP Jandy Pump
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    You want the tf-100. It's not the cheapest kit, but it's the best overall value of the kits that actually include the tests you'll need that also give reliable results.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Yes, what SeanB said. A test kit is not the place to try and save money. Inaccurate test results will lead to far more expensive mistakes later on. A top quality test kit will more than pay for it's self in the long run.
    Thanks I will look into the TF-100.
    In Construction:
    1.5 HP Jandy Pump
