Thread: Pool stains from leafs
    I just installed a pool and we do not have an automatic pool clear. We came back from vacation and we had leafs. When I removed them it had stained the mar site. How do I remove those stains?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool stains from leafs
    Welcome to TFP!
    The leaf stains should clear on their own within a couple of days or so. This happens to my pool on occasion and they always go away on their own. Just make sure you have the proper amount of chlorine in your pool according to your CYA level. Here is a reference: Chlorine / CYA Chart
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    As Bo said, chlorine will cure the organic stains. If you want to speed up the process, just increase the FC a little above target .
    You're done SLAMing when:
    Yup. At the peak of summer I get a few of these little comet tail like stains (1 inch by 1/4 inch). They don't brush off, but they do fade in a few days as the chlorine oxidizes them. One day I carefully swam down to a fresh one and it was little bug turd or something similar (ugh). Anyway, the point is organic stains organic and leaves are very organic.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
