Thread: 24" Above Ground Pool Liner Failure-Need Suggestions
    Peculiar, MO
    6
    I have enjoyed a great summer using our 24' AG Pool. Been using the Trouble Free method of cleaning and water balance. Also went to a SWC generator two years ago. However I have closed the pool for the winter. Lowered the water level, put pillow in center and covered with winter cover. Everything fine until today. I have lost all my water in the last two days. Just pulled back the cover and found the liner torn/separated 2/3 of the way around the pool and laying in the bottom. All the water is gone. What choices do I have now to fix the problem. It is currently 26 degrees outside. Has anyone else ever run into this problem. Liner is/was 5 years old. Thanks in advance for any and all help.
    Self Installed 14,000 Gallon 24' Round AG Vinyl with Hayward 250 lb Sand Filter and 1.5 HP Single Speed Pump.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: 24" Above Ground Pool Liner Failure-Need Suggestions
    You will need to support the pool somehow until spring otherwise it has the potential to sail in the wind. Placing fence stakes all around might work.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What type of liner is it overlap,unibead ? Is the liner ruined
    Jeff
