Results 1 to 7 of 7
Thread: Pump makes a squealing nosie from cold start
    Jul 2013
    Oklahoma City
    10
    I purchased and installed a new Hayward SP2607X10 Super Pump 1-HP Max-Rated Single-Speed Pool Pump in May of this year, for 15k gallon in-ground pool, it runs on timer for ~14hrs per day and has worked perfectly.
    Middle of September I partially close the pool, add closing chemicals and cover it, half the cover is raised above the water and the skimmer works perfectly. I tested everything, pump runs, everything works fine.
    We have recently had a cold snap, so decided to leave the pump running over night (the pipes are insulated, and the filter/pump is covered and in a sheltered place, but I was playing safe) to ensure some frost protection, works fine, until the other day, when I heard a squealing noise coming from the pump, it never once made this sound during the summer.
    The symptoms are this
    After the pump has been OFF for awhile (several hours) and it turns on it will make a squealing noise
    After the pump has been ON for awhile (> than 30mins or so), most of the time the noise goes way
    It seems that after the motor has cooled down the squealing comes back, but I'm not certain of this.
    Any ideas as to what this could be causing this? It is not that old.
    Pool size in gallons - 13,640
    Filter type - Pentair Sand
    In ground
    Plaster/pebble, approx 33ft x 11ft
    Age - not sure, most likely ~20 years
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pump makes a squealing nosie from cold start
    Bad bearings. As they warm up, the action is smoother, hence the noise goes away. If you're still within the warranty period, I'd try to get it replaced.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It's better to replace the bearing now then later, also replace the seal.
    Here's some info:
    https://wetheadpumprepair.com/what-moto ... uper-pump/
    Hope it helps.
    Smykowski's Avatar
    Sep 2011
    3,065
    Just to clarify my above post, if you're inside the warranty period, I'd make Hayward replace the whole pump. If you're outside the warranty period, it's possible to do just the bearings either yourself or to source it somewhere.
    Jul 2013
    Oklahoma City
    10
    Thanks for the info - it should be under warranty as it is only 8 months old, I was expecting it to last longer that.
    In ground
    Smykowski's Avatar
    Sep 2011
    3,065
    8 months is way too short. Start with a warrany claim and see what happens.
    Jul 2013
    Oklahoma City
    10
    I just started it up again, and it is much warmer today, and it did not squeal, so temperature definitely has an impact on the issue. I'll start a warranty claim.
    Thank you all and have a wonderful and happy Thanksgiving.
    In ground
