Results 1 to 7 of 7
Thread: Old house, old pool, can we keep it?
    Hello,
    We are moving into an old, but fixed up farmhouse, in which the owners haven't lived there for 5-6 years. They have been renting the house out and don't believe that the pool has been taken care of for that amount of time. It is a large above ground pool that a deck has been built around. It's a great pool and set up, but can we keep it? I don't think the pump has been on or it has been covered the whole time. There is greenish/black water standing in it. To say the pool is a swamp is an understatement. Is it possible to save the pool? What would we have to do? I don't want to have to pay for an expensive pool repair service to come out for them to say, you should just get rid of it. Thank you in advance for your help
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Old house, old pool, can we keep it?
    Welcome to tfp, bdiller
    If it is holding water, then the pool likely will be savable, but you will also have to evaluate the equipment. Do you know if the pump runs?
    This is a must read for you: http://www.troublefreepool.com/turni...sis-t4147.html
    Also, make sure you read through the rest of pool school (link is always near upper right of page), here are some good articles:
    http://www.troublefreepool.com/pool-...efeating_algae
    http://www.troublefreepool.com/pool-...ater_chemistry
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Hi welcome to TFP! How high is the water in the pool? Most parts can be replaced. If the pool is full and holding water then the liner is probably ok, but it can be replaced or patched it is torn. If the walls are in good shape, no creases or missing up rights then the structure should be good. If there is rust or holes in the wall they can be repaired or patched.
    Check and see if there are any plugs in the return and skimmer. Check the setting on the filter and make sure it is on filter or recirculate. Check the pump and make sure the strainer pot has a basket inside, the drain plug is snug and the strainer pot is full of water, then you can try turning on the pump to see if it works. If the pump doesn't work it can be replaced.
    Take a few pictures of the pool and equipment and we can tell you if anything stands out as a problem.
    Love TFP? Become a
    TFP Supporter!
    Thank you everyone for your help! This is such a great resource for us first time home buyers and pool owners. I've looked through those links and they are very helpful. I won't be able to take pictures for a couple days but I will post them. Should we drain the pool since that water has most likely not been treated for 5-6 years? If so how do you do this? Then would we clean it? Also, we live in Ohio what's the best way to winterize our pool? What should we be doing now? Thanks again everyone! This is going to be such a great site for us
    We also have a hot tub that comes with the house that looks like a pipe was blown on it. Where would be a good place to get replacement parts. My fiance is a great at fixing things, we just don't know how or where to go.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You should not fully drain a vinyl liner pool, especially one with an older/neglected liner.
    Here is the pool school article on winterizing agps: http://www.troublefreepool.com/pool-...20group%20pool At this point, I wouldn't worry about cleaning up the water until spring...so I would skip the chlorine (and polyquat) additions mentioned in the article. Also, you don't need to worry about covering the pool this year.
    Smykowski's Avatar
    Sep 2011
    3,065
    Ditto to all of the above. I'd spend the winter learning as much as you can and get a good test kit. Start the cleanup as early as possible in the spring - basically as soon as it's warm enough for you to tolerate being outside and when the threat of freezing is gone. It'll be too cold to swim, so there won't be the impatience of getting the pool ready in a certain amount of time.. It will be a much less stressful process.
