Results 1 to 11 of 11
Thread: Need Pump Recommendations
    Dec 2012
    Groves, Texas
    38
    I have a 26500 gal pool that currently has a single speed 2hp AO Smith motor on a hayward super 2 pump running only a 60 sq de filter. The pump seems to be on its last leg. Looking at replacing with a 2 speed but have no idea what size to replace it with. Thanks in advance.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need Pump Recomendations
    Do you know the model number of your current pump? If not, post the model number of the current motor (or both).
    mas985's Avatar
    Pleasanton, CA
    11,737
    Do you have a spa or any high volume water features?
    If no, then any small two speed is fine. The Pentair 1 HP Superflo or Hayward MaxFlo XL are good choices. The MaxFlo also comes in a VS version if you have an interest in that.
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Mas985 comprehended your post better than I did. Is your pump failing or just the motor? If it is the motor, then replacing with a 2-speed motor (keeping the pump wet end) might be cheapest/easiest.
    Dec 2012
    Groves, Texas
    38
    The pump is only for the filter. I will get the model # in a bit. It currently has a 2hp motor. Is this to much? Is it better to downsize?
    Dec 2012
    Groves, Texas
    38
    The pump seems fine. It is the motor that is going out.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by bags23
    Probably, though until you post a model number we don't know if it is a full-rated or uprated pump.
    Depends...if your electric rate is high then changing out the whole pump for a smaller 2-speed pump may payback fairly quick, though you may have to make plumbing changes. If your electric rate is not so high, then just changing to a 2-speed motor on your existing pump may make the most sense. Do you know what your rate is?
    Dec 2012
    Groves, Texas
    38
    The motor is a AO Smith b809.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Do you know the model number of the pump too? It should be on pump housing.
    Also, approximately how old is the pump? It may or may not be worth fixing the old pump depending on the age and condition. Also, a picture of the pump might help too.
    Mark
    Dec 2012
    Groves, Texas
    38
    I cannot find a model # of the pump. The housing looks to be a Hayward super 2. The pump seems fine. Also there is no main drain but 5 returns.
    Dec 2012
    Groves, Texas
    38
    Re: Need Pump Recommendations
    Electric rate is about .10KWH.
