Thread: compool cva-24
    compool cva-24
    Valve wont turn
    Aug 2010
    Dallas, TX
    4,052
    Re: compool cva-24
    Have you called Compupool? I have found them easy to work with.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: compool cva-24
    Are you using the remote or the toggle switch on the side of the actuator?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
