Results 1 to 10 of 10
Thread: Losing water
    Nov 2013
    Central Texas
    113
    Losing water
    Starting Saturday I have been loosing 3" of water a night. We have had a major cold snap so I am wondering if its just loosing the water from that evaporation.
    Nov 16-17 we had a 85 degree days so I had the pool at 94 degrees.
    Nov 22 pool was 80-82 degrees, major cold front moved into our area. Since the cold snap I have had the pump running 24/7 for the pipes. Equipment pad is bone dry no visible leaks. We have had high humidity (its been raining) but have had a lot of wind from the north. Right now the water temp is 52 degrees.
    Edit: Nov 22-Today highs have been around 40 degrees, lows 33-34 degrees
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    30,431
    Re: Losing water
    3" water loss overnight has nothing to do with temperature....you have a leak.
    Nov 2013
    Central Texas
    113
    Re: Losing water
    thanks I had a feeling that was going to be it.
    Nov 2013
    Central Texas
    113
    Re: Losing water
    starting to think its the autofill . I just plugged the return line fitting so time will tell.
    Sep 2013
    Auburn, Alabama
    73
    Re: Losing water
    Hopefully that fixes the problem.
    If not, do a 24 hour pump on (the whole time) and a 24 hour pump off test. Note the difference in water loss.
    Use a ruler taped to the pool to know exactly how much you lose.
    The Original Leak Specialists.
    Nov 2013
    Central Texas
    113
    Re: Losing water
    just an update it ended up being the poolmiser pm-101. The water was leaking at the bottom of the overflow tube. The easy fix would be to glue the overflow pipe in but the instructions say do not glue the pipe. It will be interesting to see how the pool builder fixes it.
    Nov 2013
    Central Texas
    113
    Re: Losing water
    Ok after chasing down multiple leaks and filling them I now have one final leak I need help with. The last leak is on the spa return fitting joint. The return pipe is 1.5", what is the correct way to fix this. I obviously cant re-glue it and due to it being pressure side epoxy wont work. Would a sleeved return fitting be the best option? Only other way I can think of is chipping away plaster and redoing it that way.
    Sep 2013
    Auburn, Alabama
    73
    Re: Losing water
    Quote Originally Posted by JonnyB
    Can you take some pictures?
    Nov 2013
    Central Texas
    113
    Re: Losing water
    Quote Originally Posted by Leak Specialist
    I will take some tomorrow. And post them
    Thanks
    Sep 2013
    Auburn, Alabama
    73
    Re: Losing water
    Your welcome.
