Results 1 to 9 of 9
Thread: Wash out !
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Wash out !
    Not sure where to post this so I will try here.
    Where the outlet for my pool filter runs to from the waste port washes out the dirt around or in front of the filter when I backwash the pool. I have put dirt in and in and in and it keeps getting washed out. I have been thinking about putting/making a long little concrete slab run off and I was wondering if others have had this problem? Other thing I was thinking about doing is making a long box and filling it with stone but I'm afraid the dirt will still get washed out under the stone during back washing etc ...
    Any thoughts and suggestions would be most welcome !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Wash out !
    Backwash hose would be the easiest and cheepest solution but you have to unroll and roll it everytime you backwash. It would allow you to dump the water on the grass or some other place where you wouldn't have that problem.
    Or you could plumb in a fixed line into the sewer but that would cost a bunch if you have someone else do it.
    Mark
    Mar 2007
    Morris, IL
    477
    Re: Wash out !
    How about putting sod there. it is instantly green, and it would probably love the water, plus once established I doubt it would wash out. I have a lush lawn and I don't have problems with anything like that.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Wash out !
    I use an old vacuum hose which I clamp to the port and roll up when I'm done. It has a few pinholes in it which makes for interesting fountains when I backwash. The water drains into my lawn. Because it comes out with considerable force and I wanted to prevent a washout I put a piece of wood under the hose opening so the water spreads out before it hits the grass.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Wash out !
    I will take a picture of the area I am talking about and post it. I don't think sod is will do if the dirt underneath keeps getting washed out. I dont really have a sewer near by to drain it too either. That's why I was thinking of the stones or a small run off slab. Let me post the picture and maybe some more ideas will come up ....
    Les
    Helpful Links:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Wash out !
    Ok, here are a few pictures of the area I am referring to ....
    http://community.webshots.com/album/563 ... =community
    Any suggestions would be welcome !!
    How do you add a picture directly to a post ?
    Les
    Helpful Links:
    AnnaK's Avatar
    Jul 2007
    1,134
    Re: Wash out !
    I would dig the hole out a little more, widen and deepen it, and fill it with white pea gravel.
    AnnaK
    Jul 2007
    Waterford Michigan
    36
    Re: Wash out !
    What I would try is, diging out a larger hole, install some weed block then get some crushed concrete (larger rocks) the back wash water won't move that. Foarm it to look like a river bed.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    Mar 2007
    Morris, IL
    477
    Re: Wash out !
    You could also cut the bottom 90 off, and put the pipe underground and have it come out closer to the bottom. That is what they do with drainage ponds, they will get the water to go into a manhole and then have it flow into the pond at water elevation. If you can get it to come out onto flat ground then you would be better off.
    steve
