Thread: Readings different every day.
    Nov 2013
    Texas
    8
    Our pool is only a month old. Just when I get a couple of the readings balanced, then others go out of whack. I hate to get in the habit of adding things constantly.
    Todays readings
    TA 123
    PH 7.6
    Stablizer 30
    FC 2.37
    CH 126
    I started using BioGuard BackUp, due to " Boatmen" bugs. Shocked the pool, and now the bugs are gone. Seems like the TA and PH keep bouncing daily. I treated it today with Calcium Hardness Plus. All pumps running full force, due to freezing temps.
    9800 in ground Pebble Tech Freeform. Waterfall and weeping walls. 2.0HP Jandy E Pump, Jandy 160 GMP Feature Pump, PB4-60 Cleaner Pump, 48 Sq. Ft. Jandy DE filter, Aqualink with PDA, Fusion Chlorine, Delta UV Sterilizer, Auto Fill, Polaris 3900, Anti Freeze Protection.
    30,426
    Re: Readings different every day.
    What kit are you testing with?
    Nov 2013
    Texas
    8
    Color Q
    30,426
    Generally speaking, the colorQ does not seem to be as repeatable or as accurate as the drops based kits we suggest. I think the nature of it is the discrepancies you are seeing. You can google colorQ on this forum and get lots of threads discussing it's performance.
    22,551
    Also if you can provide several sets of test results it would help us see what parameters are changing. A list of what you did to correct it will help as well.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Chlorine will change constantly, so that is normal.
    With a new plaster pool, your pH will also change constantly and the TA along with it.
    Daily chemical additions are perfectly normal, especially with your new pool.
