Results 1 to 11 of 11
Thread: Trying to source a leak
    Jul 2011
    San Jose, Ca
    16
    I performed the bucket test and found I am losing 1/2 an inch of water a day (15k gallon fiberglass pool). It appears to lose water the most at night after the pump is off (added water in the morning and did not notice any water loss in the evening). From search of previous threads, I may be losing water from a leak at the skimmer? Below are pictures I took near the basket. It appears the old seal has deteriorated and even missing in some areas. Next I turned off the pump. When the water was still, I squirted some red food color near the holes at the edge of the basket missing the seal. Didn't see the food coloring get sucked in. The food coloring just stayed suspended in the water. Any suggestions? Thanks in advance.
    15,000 gallor fiberglass, kidney shade pool. San Jose, California
    22,542
    Re: Trying to source a leak
    Have you tried letting it leak until it stops and see if it stops at the bottom of the skimmer?
    Mar 2010
    122
    Does it lose the same amount of water no mater if the pump is running or not?
    May try plugging all plumbing lines in the pool to make sure it's not the plumbing. ( skimmers, returns, vac lines)
    What type of filter do you have?
    Have you checked the light niche?
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    Jul 2011
    San Jose, Ca
    16
    I have a Pentair IntelliFlo Variable Speed Pump. Do I need to turn off all equipment and just let it leak til below skimmer and observe if water lever continues to leak? Or keep the pump at regular schedule? I'm guessing the pump will shut off once it cannot get prime.
    Jul 2011
    San Jose, Ca
    16
    Quote Originally Posted by uncfan1573
    I have a Pentair Clean and Clear Plus 420 Cartridge Filter.
    Safe to shut off the pump for 24hours to check if water lose is the same as pump running half the day?
    I will try plugging to test to rule out the plumbing. Have not checked the light niche. How to test that area? Thanks.
    Mar 2010
    122
    Where do you live? What type of weather do you have right now?
    You can take the light out by unscrewing the set screw ( should be one single screw in the top middle). And the light will come out. You can put die down in the niche and see if it sucks into the conduit.
    22,542
    Just shut everything off, as long as it's not going to freeze, and let it leak down to the bottom of the skimmer and see if it stops there.
    Jul 2011
    San Jose, Ca
    16
    I live in San Jose, California. 60's day and 40's at night. Have lots of trees so evaporation is (I think) negligible. I'll try shutting down everything and test the light conduit. Thanks.
    Mar 2010
    122
    You will be fine to turn it off. I would also plug the plumbing to see if it leaks. If it dosent leAk tonight. Maybe unplug the skimmer and see if it leaks.
    Jul 2011
    San Jose, Ca
    16
    No winterizing plugs at Leslies...have to wait a few days for plugs to come in the mail...
    Sep 2013
    Auburn, Alabama
    73
    That ring around the inside of the skimmer is just hold the basket, I have seen the skimmer structure cracked behind them but its rare.
    The Original Leak Specialists.
