Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 116
Thread: First SLAM - finished at last!
    Nov 2013
    Visalia, CA
    68
    I just got started on SLAMming my pool today.
    Was at 3ppm FC this afternoon. Added 4 gallons of 10% liquid chlorine at 4:00 p.m. Did FAS-DPD test at 4:30 and got a result of 25ppm FC.
    ETA: my other test results from today--
    CC 1
    pH 7.5
    TA 125
    CH 925
    CYA 80
    New owner of a 70s-built 24,000 gallon in-ground plaster pool with an original DE filter and Polaris 250 automated sweep
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    5:00 p.m. FAS-DPD test results:
    FC 24
    CC 2
    Pool calculator says my shock level given the CYA of 80 is FC 21. So I don't need to add any more chlorine yet, right?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First SLAM
    Right. When it falls below 21 bring it back up.
    Jeff
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: First SLAM
    Looks like you got a good start. What does your water look like? Green tint, Pea soup, or black lagoon. You can hold off on testing CC's at first. From your test and times you burnt 1ppm in 30 mins and your CC rose 1 ppm. The key is to keep your FC above 21. That might be testing every 2 hours the first day. As you notice your FC becoming more stable between test, then you can see where your CC's are. Also watch your filter. DE filters are great at keeping a clean pool clean but are a pain clearing a dirty pool. Good Luck
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    Wondering if I can expect it to fall at a fairly linear rate? That is, if it fell 1 ppm in 30 minutes, can I use that to predict when it might fall below 21 and retest then or do I need to keep testing every hour?
    As far as the appearance of the water, it's a little dull/cloudy. There are black algae spots on the walls and floor of the pool, particularly in the deep end. Here are some pics from yesterday (11-22-13):
    My FC levels have been falling rapidly ever since I took over the pool in the middle of October. In the meantime we had some filter and sweep issues that allowed a lot of leaves and bugs to build up in the pool for a week or so, and unfortunately the FC level dipped well below recommended levels several times over the past month (and even when I was keeping them within the pool supply store recommended levels that wasn't really high enough given my CYA level which I had no idea of at the time! Just got my TF-100 a day or so ago).
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    First SLAM
    If you have black algae you need to brush the spots to expose it to the high FC level. The black is like a protective covering.
    SLAMing is like a marathon not a sprint. Stay on top of it until all three criteria are meet. Back wash your filter when pressure raises 20-25% of the clean pressure. Test every hour if you can. The longer you stay at SALM level the quicker the process goes.
    Jeff
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    OK tested the water at 6:45 or so and FC had fallen to 20.5.
    So do I just bring it up to 21 or do I shoot a little higher?
    ETA: Just realized the float is still in the pool with the trichlor puck inside ... I should take that out, right?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First SLAM
    Yea take the puck out. Bring it back up to 21-22 ppm. Your doing well. How's the filter pressure doing. Your are running pump the whole time right ?
    Jeff
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    Took the puck out.
    My husband did another vigorous scrubbing of the biggest black algae spots.
    Pump (and pool sweep) has been on since I started. Filter pressure has risen from 13 (where it's been pretty much since we cleaned out the filter and replaced the grids and DE a few weeks ago) to 14.
    Between dealing with the kids and getting dinner ready and eating it, time got away from me and I hadn't added any chlorine yet, so I retested at 8:15 to make sure I added the right amount. FC was still 20.5, so that's good, right?
    I added 1 quart of 12.5% liquid chlorine, which The Pool Calculator said would get FC up to 22. I'll check it once more before I go to bed tonight.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    First SLAM
    You guys are doing a great job !! Keep us posted on the progress !
    FC is starting to hold longer. When you can pass the OCLT loss test that's a big one. pool-school/overnight_fc_test
    Jeff
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    Last check before bed for first OCLT.
    FC was 21.5 at 10:00 p.m.
    Checked CC just because I was curious and it was 2.5.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First SLAM
    We'll see where it's at in the morning. CC has to be 0.5 or less to pass that test. Do you have any light niches ? If you do check them to see if anything is in there.
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: First SLAM
    Better to have a little more FC than even a bit too little, so dont worry if you bump it to 25-30. It wont be wasted, and it will come back down. Nearly impossible to guess how long it will take, but you are doing well, and Jeff has you covered. Good luck with it!
    Essential Links:
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    This morning's test showed FC of only 16.5. Pretty big overnight loss... I will target higher FC levels before bedtime tomorrow night to hopefully keep it at slam levels overnight.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First SLAM
    That's fine. In the meantime bring it back up to SALM level and stay on top of it. Keep brushing the black algae to expose it. By the way, what type of brush are using ?
    Jeff
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    Added 1 gallon, 2 quarts and 1 cup of 12.5% chlorine, which is supposed to bring level up to 25. I'm going to be at church most of the morning ... can check level maybe before I go at 9:00 and then after we get back around lunch time.
    Brushed again, with a wire brush that looks pretty much like this one:
    http://www.poolweb.com/Home/Other-Produ ... fgodBTAA5g
    By the way, are there tutorials on how to open up a light niche? Is it possible without entering/draining the pool?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    First SLAM
    Good job!! Check it when you get back and bring it back up if need be.
    If you can reach over the edge there should only be a couple of screws for the light niche. I think.
    Jeff
    Nov 2013
    Visalia, CA
    68
    Re: First SLAM
    Checked FC before left for church and it held steady at 25. Checked it again just now (1:15 p.m.) and it had dropped to 23.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First SLAM
    Keep SLAM' n away !!
    Jeff
  20. Back To Top    #20
    Re: First SLAM
    You can remove the light without draining. You're going to have to get wet to do it. You don't have to actually get in the pool if you can reach it from the deck, though. There should be 1-4 screws in the underwater ring around the light that you'll need to remove. Most lights have just 1. The light itself will have a long cord so that it can reach the deck once freed from the niche. (Turn the electricity breaker off before you remove the screw(s).)
    However, I would consider waiting until the visible algae is gone before checking the light. You don't have a swamp, and algae may not have gotten in the light niche. If you get to the point where no algae is visible, and you still have overnight chlorine loss >1ppm or CC > 0.5ppm for a couple of days, then it's time to check the light. Of course, if you don't mind checking now, it certainly won't hurt.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
