Results 1 to 11 of 11
Thread: Entire Pool build
    Nov 2013
    Central Texas
    113
    Entire Pool build
    I first will say I have been a lurker on this site for over a year now. I thought it was time to post up my pool build. This wasn't our first pool but it was the first pool build we have experienced. We started looking for builders in November 2012 and found a builder in February 2013. April 19th was the day we broke ground. I have many picutres (over 500) that document the build but will only show 37 to keep it as short as I can.
    Lime stone was on the ground so the entire build was using a breaker
    after two weeks of house rattling forms are up
    Most of the rebar
    Plumbing completed
    Gunite, Texas Gray Lueders for coping, Texas mix for spa, and Marcelo putting up 6" NPT tile
    Decking. We are on a PUE. The walkway and pool are right on the PUE line
    Natural Concrete with salt finish
    Equipment installed
    Quartzscape French Gray and pool filling
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    Nov 2013
    Central Texas
    113
    Re: Entire Pool build
    18 yards of Sandy Loam as base
    After the sandy loam the entire landscape was done by myself. I did rent this fun little machine. That day we got 6" of rain and the pool got close to overflowing. The first time I used the backwash hose it blew up in my face. I used this dingo to move 35 yards of rock. 13 yards of mulch and 9 yards of top soil.
    Because of the PUE and unable to put decking on that side of the pool I put down 35 yards of Llano River Rock
    redoing sprinkers, and hardlining the backwash
    being in a flash flood prone area I had the decking guys install two 4" pipes under the walkway I also installed the backwash pipe to the drainage pipes
    Backwash glass installed and works!
    mulch beds and 2" of premium top soil for the grass
    3 pallets of St. Augustine Palmetto
    Grass, The Texas Mix looks out of place in these pictures. The reason I used Texas Mix is because on the front of the house it has texas mix flagstone. Just not in the back
    Mackenzie enjoying having her backyard back
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Entire Pool build
    Welcome to TFP !!
    Very very nice looking pool !!I'm sure it will see a lot of use.
    Jeff
    Nov 2013
    Central Texas
    113
    Quote Originally Posted by pwrstrk
    Welcome to TFP !!
    Thanks! Trust me it I am in it almost everyday! The main requirement we gave to the pool builders was a free form lap pool.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    Nice work on that landscaping. Very nice! If my pool ever gets finished, which hopefully will be sometime next week, I will also be doing all of my own landscaping. Every inch of it by myself.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'd say welcome JonnyB, but I already did that elsewhere. Thanks for posting up your build. Looks like they built you a fine pool!
    Essential Links:
    Nov 2013
    Central Texas
    113
    Quote Originally Posted by Divin Dave
    Thanks! I had many delays and mistakes that set the pool build back. Doing your own landscaping is extremely satisfying! Knowing that its all up to you. Your no longer relying on or in my case just hoping they show up. Everyone asks if I would do it all over and of course I would. I did all the work in 100+ degree days and would do it all over again.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I like that backwash sightglass...a lot. I may have to find one of those.
    Essential Links:
    Nov 2013
    Central Texas
    113
    Quote Originally Posted by Brushpup
    its a hayward part. I have the 2" version.
    Nov 2013
    Central Texas
    113
    Here is my list of headaches from the pool build.
    1. Pool layout on ground was wrong. Should have been 8' from fence and was 14'. Pool builder didn't believe me.
    2. Excavator dumped too much rock in the pool before rebar where the pool should have been 4.5 feet it was 18" again I was wrong.
    3. Decking was installed into the PUE even tho I had a landscape line up to show the PUE and not to go into it.
    4. Rebar decking was not tied together so failed inspection on a Friday. Concrete guys never showed SO ended up spending that Sunday tying up all the rebar to pass the Monday inspection (yes my work passed)
    5. Pool builder called in for the wrong inspection and concrete was almost poured. If I didn't look up the permit the concrete would have had been removed.
    I have more little things but those were the big issues I can think of.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I know my list will be coming and I dread it. Seems like it's impossible for any homeowner's big project to go perfectly.
    Essential Links:
