Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Under Winter Storm watch
    Nov 2013
    Central Texas
    113
    Being in Central Texas I do not close my pool. Under normal freezing conditions I just let the pump do its work. We have the chance of freezing rain and or sleet. So I am wondering if I should take any precautions. My equipment is outdoors. I have my grill cover over the heater and a sheet of plexiglass protecting the pump. Anything else that I should try to protect?
    Thanks
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Under Winter Storm watch
    Hey JonyB! Welcome to TFP!
    Just do what you normally do then. It doesn't look like this one will even get low enough to worry at all. I see 42 in Austin right now My buddy is down in La Vernia with 46.
    Essential Links:
    Nov 2013
    Central Texas
    113
    Thanks I am not concerned with the pipes at all pool temp is 65 right now so as long as the pump is moving the water the pipes are fine. I am more concerned about ice and the motors or the heater. Should be fine I just like to worry
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, if it gets closer to freezing then keep an eye on it and run things a little. Should be fine.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Quote Originally Posted by Brushpup
    Mid 40's and rainy over here in Longview the last day or 2. Not too bad compared to up North, but for our part of Texas we consider it to be bloody well cold! Brrrr!
    Spost so be down in the mid 20s at night mid next week.
    Divin Dave,
    Aug 2010
    Dallas, TX
    4,052
    I was fine when we were in the middle of the huge ice event a couple of years ago (Super Bowl in Dallas). We saw 19 degrees and I had no issues.
    Nov 2013
    Central Texas
    113
    Thanks everyone. I am loving how everyone that has replied is from Texas
    Aug 2010
    Dallas, TX
    4,052
    Because we are all indoors today. It's too cold outside for a native Texan.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by RobbieH
    You got that right Robbie! I'm getting Cabin fever already though. Think I may have to make a run to HEB for the Missus her in a bit. How may time you braved it to see that nice "new" pool?
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Come on guys,can't be that bad there !! To night it's going down to 16 and tomorrow flurries with a high of 32 and 20 mph winds.
    Jeff
    Nov 2013
    Central Texas
    113
    Quote Originally Posted by pwrstrk
    Anything under 60 is cold. Now when its in the 30s!?!?! then Canada is trying to take over
    Aug 2007
    near the swamp
    806
    It's currently 76F and humid outside.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    You got that right! About the only useful thing I have done all day is put another log in the fireplace!
    Divin Dave,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Quote Originally Posted by JonnyB
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    A Men to that. I live as far North as I ever want too!
    Essential Links:
    Nov 2013
    Central Texas
    113
    The winter storm watch has been upgraded to a winter storm warning. Pool is good to go.... now to protect my citrus trees
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Oh no....
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    How much snow are you guys supposed to get, 1-2 feet ?
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    All frozen precip so far. We have ICE on the trees and everything else!
    Two feet of snow to us, is like 5 ft to you.
    Go ahead and snicker, we know we are wimps in winter.
    Essential Links:
  20. Back To Top    #20
    Nov 2013
    Central Texas
    113
    The only main concern I have now is if we have power outages due to ice snapping the lines. Kinda hard to run the pump without power.
