Thread: Pump shuts off after 10-20 seconds
    Hi guys. I'm new to this pool thing, so I have no idea what to do. Hope someone can help.
    This morning, the pump is off, so I went to clean the basket (the one attached to the pump). After I opened the basket lid for maybe 5 seconds, the pump started to run. I ran to the on/off switch and turned the pump off. It ran dry for maybe 3-4 seconds. I turned it back on and it ran for maybe 5 seconds and shut itself off. I went to breakfast and let it cool thinking it was due to some thermal protection and it turned on for another 30 seconds before shutting off again. The pump seems to run fine and no excessive noise when it was on.
    Now, my question is:
    1. It was strange that the pump was turned on but not running before I opened the basket. why is this so?
    2. is the pump damaged? What can I do to diagnose this?
    3. how do I get it to start again?
    Thank you!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump shuts off after 10-20 seconds
    It is probably the thermal protection circuit kicking in. This usually happens when the motor is overloaded by either an impeller restriction or bearing failure. I would take the pump wet end apart and inspect the impeller and diffuser. At the same time, you can spin the motor shaft and see if it feels like there is any friction in the bearings.
    Mark
    Thank you! That makes sense. I will check that out tomorrow.
