Thread: High CYA and algae
    High CYA and algae
    Mod edit: Split from another topic. Please start a new topic to get your specific questions answered.
    Smykowski
    Cya 115 algae everywhere 9800 gallons..
    18'x36' In ground pool - roughly 25,000 gallons; Sand filter; Vinyl liner;
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    High CYA and algae
    computhan14. Please put your pool info in your sig. It'll help us help you. How did you obtain that CYA level ? If your CYA level is truly 115 you need to get that level down to 30-40 ppm. To do that you will need to do a partial drain and refill. Then you will need to SALM the pool.
    pool-school/shocking_your_pool
    With 9800 gallons to lower your CYA level you need to replace about 65- 75% of the water. It may make sense to drain it and start over.
    Jeff
