Thread: Various Jandy Air/Water temp sensor
    Sep 2013
    Simi Valley, CA
    73
    Does anyone know what the difference is between the various Jandy temp sensors? 7784 vs 7785 vs 7790?
    Any guidance would be greatly appreciated!
    28K IGP, AquaPure 1400 SWG, Inteliflow filtration, Inteliflow spa, pentair 1.5HP water feature pumps, pentair cartridge filter, 2.5 / 3" plumbing.
    Oct 2012
    36
    Re: Various Jandy Air/Water temp sensor
    Quote Originally Posted by garykli
    Only the length of the wire. Each sensor is identical and can replace one another if necessary, distance of wire permitting.
    Sep 2013
    Simi Valley, CA
    73
    Great, thanks! Jandy couldn't have made this more confusing if they tried!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just be aware Jandy temperature sensors and Hayward temperature sensors are not interchangable, they have different response curves, which has to make you wonder about those that are sold as generic replacements for both
