Thread: Winterizing an in-ground: alternatives to lowering water?
    All,
    I'm just about to pull the trigger on closing the pool (yes, I'm very late!) and wonder if there's an alternative to lowering the water level to below the tile and skimmer line. The above ground guys use pillows to keep the ice from pushing the walls of their pools apart, so I wonder if there's a way to do a similar trick with in-ground pools. If not, isn't it about time somebody invented a way? (I don't have any in-wall things to worry about, except lights which stay well below the waterline. My stuff's in-floor.)
    Reason I'm asking is because I have a great safety cover which can be used as a winter cover per the manufacturer... provided the water level doesn't dip quite that low, and I'd love to avoid buying a Loop-Loc or equivalent.
    Bill
    Bill Eccles
    Tolland, Connecticut
    16'x40' CPC Athens IG fiberglass, 23,000gal., installed 6/2010
    Hayward AquaRite Pro salt system, C5025 cartridge filter, SP4007X10 pump, H400FDP heater
    Aquamatic Hydramatic safety cover, Vantage in-floor cleaning system
    38,301
    Re: Winterizing an in-ground: alternatives to lowering water
    Where are you?
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you.
