Results 1 to 7 of 7
Thread: Pump Repair
    Pump Repair
    My Hayward pump needed a rebuild last spring. I sent my pump to a well advertised pump repair company online, all over U-tube, that sells pump repair kits and ended up having to get my money recouped through my credit card company's fraud section. I should have done my research but I let my guard down.
    Does anyone out there know of a reputable company that rebuilds pool pumps of sells rebuild kits?
    Thank you in advance,
    Jp
    IGVP 20X40 30,000
    Hayward 1.5gpm Superpump
    Blue Pearl Robotic Cleaner
    Dad, can we go in yet?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pump Repair
    Welcome to the forum, and sorry to hear your bad luck. Someone here may have a suggestion, sorry I don't.
    Essential Links:
    38,354
    Re: Pump Repair
    What exactly do you need repaired? Anything beyond a capacitor or maybe bearings and it almost does not seem worth it to repair ... if even possible.
    30,426
    Re: Pump Repair
    +1 what jblizzle said.
    If you're handy and want to mess with it, we can help here with bearings and capacitors and seals.
    Beyond that a pool repair place may charge you somewhat close to new pump price and you'd still have an old pump.
    Re: Pump Repair
    Bearings for in a Hayward 1.5gpm Superpump...I think...they started making noise at the end of pool season and slowly increased in noise.
    IGVP 20X40 30,000
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pump Repair
    I really need to do a "How to" the next time I do bearings...
    If you're handy, they're very doable. You can buy them from a pool supply place (search pool pump bearings on Google), or you can buy sealed bearings from any industrial supply place as long as you can match them. When I did mine a couple years ago, I took the pump apart, and pulled the old bearings off. There was a number stamped on the seal, and I was able to match them on Grainger's website. Less than $20 for the pair.
    You'll need a cheap puller, and to put them back on you'll need access to a press (the better way) or you can hammer them on with a piece of black pipe (the way I did it).
    There are lots of videos on YouTube that can give you a little more visual on how it's done.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump Repair
    There are a ton of bearing replacement videos on YouTube: https://www.youtube.com/results?search_ ... rings&sm=3
    Mark
