Results 1 to 10 of 10
Thread: time for new plaster . . .
    pikeman's Avatar
    Jul 2008
    Pflugerville, Texas
    68
    Our pool was lined with pale-grey "swirly-looking" Marcite 17 years ago and it's time for new lining.
    I was interested in Pebble-sheen, but the all the certified installers I've been talking to said that the product is too expensive and two of them have suggested the products from Wet Edge Technology as an alternative. Wet-edge has a polished surface that looks like terazzo that is very expensive too due to the need for post-cure polishing, but we actually are favoring their basic quartz enhanced material and not using any pebble-type finish at all.
    They said that the pools with the high-end finish polished finishes are usually very elaborate where cost is not an obstacle. As simple working-class folk I appreciate knowing this!
    So, has anyone used Wet-Edge? We're favoring the lighter colors for a blue water color. The pool is in full sun 12 hours a day, so we also need to go light to minimize the heat load.
    Thanks
    Pete
    20K IG, WetEdge technology lined pool, TF100 Test Kit, CircuPool RJ60+, StaRite pump, Hayward DE filter, Hayward Navigator pool vac. Zodiac MX8 vacuum thrown in garbage.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: time for new plaster . . .
    We've had lots of folks here use Wet-Edge, and there's no problem with the product itself. Any plaster finish can look great or horrible, depending on the skill of the installer!
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    We are scheduled to have wet edge quartz - the color we chose is Barbados, It's a darker blue. We are a couple of weeks out I think, but I'll post pictures when it's done. Our PB said it's much smoother than even the pebblesheen finish and he's put it in several pools and loves it.
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Aug 2010
    Dallas, TX
    4,052
    Wet Edge has pebble surfaces too, not just the polished surface. See the Pearl Matrix. http://www.wetedgetechnologies.com/comp ... arl-matrix
    I just had the polished surface put in (Prima Stone) and it's beautiful. Of course it's way too soon to talk about durability...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would choose Wet Edge over PT for a lot of reasons, but mostly because I believe PT is way over-priced. I think WE is a fine product, and all the info I can find has been very positive. WE was started by defectors from PT and I think you can argue they are doing a better job. Certainly in terms of choice they are. Since I cannot get it, I'm going with a very good Quartz finish from CLI, and think it will be excellent. Good choice looking at Quartz. I think the finish is a place people skimp and that is one place you should spend as much as you can reasonbly afford. IMO anyway. Very important decision. We too are in the lighter camp for color for the same reason, but we are the oddballs. For some reason everyone seems to want the really dark finishes. Check out Wet Edges youtube channel...they have a ton of info and good videos of finished pools too.
    Essential Links:
    Aug 2010
    Dallas, TX
    4,052
    You can follow my Wet Edge install here:
    restoring-my-pool-t71681.html
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    I too have Wet Edge Pearl Matrix (pebbles). Only good things to say about it though in hindsight I may have preferred putting the polished (Prima Stone) in the hot tub as I love the pebble in the main pool but a smoother surface in the hot tub may have made more sense.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    A lot of people do something similar in spas like that or tiles for smoothness.
    Essential Links:
    May 2013
    4
    I also have the Barbados. It looks awesome with the Pure White LED light.
    Sep 2013
    DFW metroplex
    738
    Texasjeff - could you post a photo of your pool - would love to see the color?
