Thread: Steel filings/dust in Pebble Sheen pool
    Jun 2013
    Austin, TX
    70
    Hi, yesterday (11/21) I had to have some railing fixed around my pool and the contractor cut it on my deck, leaving a fine black dust (steel) I was able to wash 90 - 95% down into the deck drain, but I'm pretty sure some of it made its way into the pool. I thoroughly vacuumed and swept, and have been running filter and Polaris cleaner non-stop. Any other preventative measures I should be taking that anyone could suggest? Thanks!
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Steel filings/dust in Pebble Sheen pool
    You might pull your cartridges and clean them or at least inspect for rust signs.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yeah, I'd want to clean those carts out for sure!
    Jun 2013
    Austin, TX
    70
    Thanks, I will do that tomorrow. Too bad this weekend is 'winter' in Texas!
