Thread: Multi valve
    May 2013
    Cyprus
    159
    Multi valve
    Hello
    I am going to check a friends pool pump romm as his pool guy said that the multi valve needs replacing. It is 7 yeas old. Is their anything special I should be looking for.
    Thanks for any help.
    Living in Cyprus
    Still enjoying life
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Multi valve
    I may well, but I'm curious why he didn't replace it if so? Maybe it just needs the spider gasket replaced. If you go take a look see what condition it is in and find out why he says the valve is bad.
    Essential Links:
