Thread: Hot tub flo code
    Hot tub flo code
    I own an Alacante III spa made by reflections. I am getting a flo error code on my control panel. I have checked for an air lock at the pump and replaced the filter. There is not a pressure switch on the heater nor can I find a flow switch anywhere. Do you know of anything else I can try or know if or where there is a flow switch or what may be causing this code. I believe that Vita spas has taken over reflections spas
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hot tub flo code
    Welcome to the forum Wennis!
    I cant help you with a flow code error, but someone else may be familiar with that. Glad you found us.
    Essential Links:
    22,553
    I found the manual but it doesn't have any troubleshooting guide and certainly no wiring schematic. If you have a schematic you should be able to locate the flow device.
    Since it's giving you a "Flo" error it almost has to have a flow sensor of some sort.
