Results 1 to 9 of 9
Thread: filter pressure does not increase
    Sep 2013
    Bakersfield California
    34
    Hi All,
    I have been taking care of our pool for the past 3 weeks and everything has been going great. However, the sand filter pressure hasn't changed at all. The last time the filter was back flushed was on the 31st of October and since then the pressure has not gone up at all and has been sitting at 16 PSI. I know the gauge is working because when I just circulate the water in the spa the pressure goes up to 22 and then when it is the pool and spa it does come down to 16 again. The gauge was also very recently replaced and seems to work fine. However, I do not see any change. The pool looks good and all my TF-100 results are in my signature. The filter is a Pentair Titan II. Anyway the pool looks great so I am wondering whether I should back flush it or not. The pool guy who was taking care of the pol before I bought the house was back flushing every week and he told me to do the same but I am trying to follow the 25% pressure increase rule. Moreover, I would like to mention that I do not see any major change in the water flow but this is based on qualitative measures, i.e., the waterfall from the spa to the pool seems to look the same as 3 weeks ago. Please let me know if I should just back flush it or wait for the pressure increase. Thanks a lot.
    Chris.
    12700 gallons
    IG pool and spa
    plaster
    Sand Filter Pentair Titan II
    Pentair Whisperflo single speed pump WFE 4 (1 HP)
    Built in 2005
    SWG equiped, Zodiac LM2-24
    CH 340, PH 7.8, FC 8.5, TA 90, CYA 80, SALT 4000, CC 0
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: filter pressure does not increase
    As long as your water looks good and the return flow is good you should be fine. If you plan to close it for the winter then you should back wash it at that time.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Unless you get mountains of dust in the pool, I wouldn't worry. It sounds normal to me.
    Sep 2013
    34
    Thanks well in Bakersfield the winter is so mild that I don't need to close it. I will leave it as is! Thanks again guys!
    12700 gallons
    IG pool and spa
    plaster
    Built in 2005
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by cbrown91
    This is one of the side benefits of using TFPC. Instead of your water just looking clean, it's actually clean, and it takes a long, long time to clog up a filter.
    Sep 2013
    34
    Yes I am starting to see that. The pool maintenance person though was probably ruining the filter by flushing it every week. That kind of ignorance is quite unbelievable.
    Thanks again.
    Chris
    12700 gallons
    IG pool and spa
    plaster
    Built in 2005
    mas985's Avatar
    Pleasanton, CA
    11,742
    Just curious, what size is your sand filter?
    Mark
    Sep 2013
    34
    That I don't know... I will look it up and report back.
    12700 gallons
    IG pool and spa
    plaster
    Built in 2005
    Aug 2010
    Dallas, TX
    4,052
    I only have to backflush a couple times a year, 3 tops. Welcome to having a clean pool!
