Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: What to do after I refill my pool?
    Jun 2013
    Southwest Arizona (Yuma)
    125
    Will be done with the acid wash tomorrow morning and wondering what I need to do when I refill the pool? I would assume I would test the water to get a "baseline" then go from there but I could be wrong? Anyone got any suggestions on what I need to do or what I should have on hand?
    Thanks
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: What to do after I refill my pool?
    I would run a full series of tests and dose based on those results. At a minimum, you will want to have bleach, granular CYA, and muriatic acid (MA) on hand. Just don't go over board stocking up too much on the CYA and MA unless your test results indicate a high need for either.
    Jun 2013
    125
    Thank you Bo...pools filling now
    My pool:
    Jun 2013
    125
    Took a water sample to Leslie's yesterday
    FC - low (no reading given)
    CYA - low
    TA - 100ppm
    PH - 7.6
    So I bought all the stuff they recommended and followed the instructions they gave me to add it.
    1. Added metal free
    2. Added stain and scale remover
    3. 4hrs later added 2 gallons of liquid CYA
    4. Half and hour later added 2lbs of chlor-brite granular chlorine
    So the last night we had a storm roll in and it rained HARD all night so I decided to use my test kit for the first time and test the water. I'm using the FAS-DPD kit from Leslie's recommended here
    Here are my results:
    FC - 8
    CC - .5
    PH - 8 (took 3 drops to lower it to 7.6)
    TA - 160ppm
    CH - 280 ppm
    CYA - 42ppm
    Used the Water Wheel and the Saturation Index is .6
    Ok if I am right I know my FC, CC and PH are really high.. And TA is a little high as well.
    I'm going to back flush the filter in the morning then do another test but I believe it will be the same result. What I'm confused about is correcting these parameters and where to go from here??
    My pool:
    30,421
    I would start by reading "The ABC's of Pool Water Chemistry" up in Pool School.
    Secondly, you should really do your own testing and stay out of the Pool Store. The advice you get there will never match what we suggest and their testing will never match the accuracy you can get by testing your self.
    So, the only pressing issue you have is the pH which you should lower to around 7.5 with the addition of muriatic acid. Use Poolmath to calc your dosage.
    What does your water look like?
    Jun 2013
    125
    Thanks and I know better but just felt overwhelmed and took the easy route I guess
    $300 later and here I am lol!
    Water is a little cloudy main drain is visible but barely
    Thanks again
    My pool:
    30,421
    Hmmmmm. Your test results do not indicate the need to SLAM your pool but I would suggest you do this to get that pool crystal clear.
    1. Run your pump 24/7
    2. Brush and vacuum as necessary. Backwash your filter if the psi goes up by 25% over clean pressure.
    3. For now, maintain an elevated chlorine level of 8-10 ppm while you are doing ALL of the above.
    You should see slow improvement in the water clarity over the next few days and your pool should sparkle soon after that.
    Keep us posted. Test often and report your results.
    Jun 2013
    125
    Ok will do thank a bunch!
    My pool:
    Jun 2013
    125
    As of this morning:
    FC - 8
    CC - .5
    PH - 7.8
    TA - 160ppm
    CH - 280 ppm
    CYA - 42ppm
    I did a backwash yesterday and the pressure was initially down to about 15psi but this morning it was back up to 20?
    Pool is still cloudy but only when I sweep it, there is alot of white dust almost like new plaster? Im planning to vacuum tomorrow and maybe backwash again.
    My pool:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would backwash now. Your 25% above your clean pressure.
    Jeff
    30,421
    + 1 what pwrstrk suggests.
    Jun 2013
    125
    Quote Originally Posted by pwrstrk
    Unfortunately Im at work today so I cant do it. I will do it first thing tomorrow morning before I vacuum.
    My pool:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That'll work !
    Jeff
    Jun 2013
    125
    Ok I backwashed again this morning. Think I added way too much DE the first time. Added the right amount this time and clean pressure is sitting right at 10 psi. I couldnt vacuum because my hose is junk. So I swept again until I can go get a new hose.
    Test results:
    FC - 2
    CC - 0
    PH - 8
    Added the recommended amount of bleach and acid according to poolmath and I will test again a little later.
    My pool:
    Jun 2013
    125
    Test results this evening look pretty good.
    FC - 7.5
    CC -0
    PH - 7.8
    Water is clear just need to vacuum there's a lot of "dust" on the bottom when I sweep it the pool gets very cloudy
    My pool:
    Jun 2013
    125
    What to do while Im away?
    Keep your posts under one topic because people need to see your history and test results if they are to help
    I just refilled my pool after an acid wash and discontinued my pool service. I wanted to start off on the right foot so Im using a good test kit and the BBB method. Everything is balancing out well and the water is very clear.
    My worry is we are leaving tomorrow for the holiday and wont be back until Sunday. Now that the pool is looking good and I've gotten off to a good start I dont want things to get fouled up.
    The pool gets quit a bit of sunlight so I'm wondering if I should put some Trichlor tabs in the floater and put it in there while I'm gone? Should I be worried about the PH?
    Thank you,
    JB
    My pool:
    30,421
    That would work but I would rather see you combine that by elevating your chlorine up to about 10-12 with liquid AND add about 5 tabs to the floater.
    The tabs slowly increase your CYA (that's bad) but four won't hurt too much assuming you are still at 42 CYA.
    Jun 2013
    125
    Ok thanks, sorry about he additional topic just thought that question had to be in a seperate category.
    I did test everything yesterday CYA is still at 42
    There was also no change in the TA or CH levels
    Thanks again.
    My pool:
    Jun 2013
    125
    I hope you all a a great Thanksgiving!
    We just got home last night and I did a full set of tests this morning
    FC - 4.5
    CC - .5
    PH - 8.0 (probably higher sample was real dark)
    CH - 280
    TA - 160
    CYA - 45
    going to Poolmath to see how much Bleach and acid I need to add.
    My pool:
  20. Back To Top    #20
    30,421
    Take the tabs out if you have not already done so.
