Thread: Whirlpool jacuzzi help
    Oct 2013
    29
    I noticed in the owners manual it says to " Close the drain valve on the suction plumbing." as part of the initial startup procedure to dissinfect the hot tub... my question is, where is the drain valve on the suction plumbing?
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Whirlpool jacuzzi help
    If you look at the side of the spa where the control panel is there should be a removable cover to gain access to the spa equipment there you will find what your looking for.
