Thread: Jandy 2440 issue
    Jandy 2440 issue
    My Jandy 2440 is not stopping in the correct position when going from Spa mode to pool mode. It is not stopping at all, basically just making complete cycles. When I remove the handle and cover from the 2440 and cycle between SPA and pool it works fine. As soon as I re-install the cover and handle the issue starts again. The actuator is about 11 years old, should I replace the switch, or the entire unit? I assume the Jandy 2444 is a drop in replacement for the 2440.
    Thanks.
    22,553
    Re: Jandy 2440 issue
    It's likely something binding tripping the switch early inside the unit. At 11 years old, I'd just replace it and then see if I could figure out what is wrong.
    Thanks, I am replacing the actuator today.
    Oct 2012
    36
    Quote Originally Posted by MacPool
    Thanks.
    This is typically a damaged micro-switch. Rarely, both wires to the mucho-switch shorted together our the cam can be spinning on the output shaft.
    You're right to simply replace the actuator at it's age. The 2444 JVA will directly replace your current one. The part number for it is 4424. And that's not a typo
    Installed a 2444 today, about a 20 minute job, works perfectly.
