Results 1 to 11 of 11
Thread: I don't need help yet but wanted to say hi
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    located in the Desert Southwest Area of the United States and looking forward to soak up and help with more information. I have owned pools for over 33 years and always managed to figure most problems out. The one problem I have now is my cool decking is coming up
    Thanks
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: I don't need help yet but wanted to say hi
    Welcome to the forum!
    You have come to the right place to "soak up" pool-related information.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum Mark!
    Hope you stick around and enjoy TFP
    Essential Links:
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Mark R
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Welcome!
    And let me be the first to say, "Can you post a full set of test results?"
    Mark R's Avatar
    Nov 2013
    166
    I'll work on this Richard, thank you for the welcome everyone.
    Mark R's Avatar
    Nov 2013
    166
    Quote Originally Posted by Brushpup
    I see we're on the same watch forum too
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Indeed we are Mark! Sorry it didn't register straight away.
    Good to see you over here!!! This is almost the pool version of TRF. Lots of good people here and a whole lot more good info. I'm a little surprised so few responded about their pools over there, but hey, it isn't the pool time of year. The funniest comment though was someone saying "They have Pool Forums?" Everyone over here will be stunned and ask the same about watch forums. But hey, if 100 people are interested in it, there's a forum for it.
    Glad you made it over!!
    Essential Links:
