Thread: Just making sure I have done all I need to do.
    Jul 2011
    Southwest Indiana
    61
    Aside from the chemical process of closing a pool ...... here is what I have done.
    I have individual pipes for each of two returns, 2 skimmers, 3 deck jets and a main drain. Each pipe lands at the pad with a union.
    I did not drop the water level at all ... auto cover.
    I took loose the unions from the equipment pad and physically removed the lines from the filter, pump and heater. I drained the lines.
    I removed the plug from the sand filter.
    I removed the plug from the pump. After letting the water drain from the pump I poured antifreeze into the basket area until antifreeze was running out of the drain plug hole.
    I removed the brass eyes from the pool end of the deck jets and used a shop vac to blow them out from the pad. Once most/all water was blown out I poured antifreeze into each pipe from each end. I closed the valves on the pad end and replaced the brass eyelets (sideways so they are closed off) on the pool end.
    I purchased threaded plugs with the o-rings.
    Using a shop vac I blew each return line from the pad end. After several seconds of just bubbles coming out of the return and while the shop vac was still blowing I screwed a plug into the return. I then poured anti freeze into each return line from the pad end and closed the valves.
    Using a shop vac I blew each skimmer line from the pad end. After several seconds of just bubbles coming out of the skimmer and while the shop vac was still blowing I screwed a plug into the line. I then poured anti freeze into each return line from the pad end and closed the valves.
    I made a cap with a valve stem for the main drain and used a compressor to blow out the line. After several seconds of just bubbles I closed the valve and removed the cap with the valve stem. I poured a tiny bit of anti freeze on top of the valve ball and was getting bubbles from air slowly bleeding past the valve. I put the cap/valve stem back in place and opened the valve again. Using the compressor I ran more air through it. Closed the valve and left the cap/valve stem in place.
    From the electrical panel end I poured antifreeze into the conduit for the Color-Logic light .... it is my understanding that these lights allow water to get into the conduit. There is no way I can think of to blow the conduit out??
    I placed a 75% full gallon anti freeze jug in each skimmer. Upside down. This keeps about 2" of the jugs bottom above water line and the rest under the water line.
    I have thought about, but not done, taking a second partially full anti freeze jug and squeezing it into the skimmer mouth.
    Thoughts? Ideas? Am I missing anything.
    Hate to be a pest but this is my first winter with my first pool and I dont want to mess it up.
    Thanks in advance.
    19600 gallon 18x36 IG vinyl liner over full length steel steps. 4'x8' sun ledge. Sport bottom 3.5-6.5'.
    Hayward equipment including SP3200 VSP, Pro Logic, T-15, S210S sand filter, 140k Heat Pump and Colorlogic light.
    Under track auto cover.
    Jul 2011
    Southwest Indiana
    61
    Re: Just making sure I have done all I need to do.
    Any thoughts?
    22,543
    Looks like you've pretty much got it covered! Pun intended!
    I can't think of anything else that you need to do. Maybe someone will come along more familiar with your location and have some suggestions.
    Jul 2011
    Southwest Indiana
    61
    It gets cold here but not like further north. Zero and slightly below are possible each and every winter .....
    I did do a couple of extra things.
    I took closed cell pipe insulation and wrapped the mouth of the skimmers with it. I figure that would give about 1/2" of cushion on each face of the opening in the unlikely event the water freezes solid.
    I also took a half full gallon of antifreeze and wedged it into the skimmer mouth.
    I am not worried about the pipes at all .... they are pretty much full of anti freeze. I am apprehensive about the skimmers though.
    22,543
    I think by doing what you have to the skimmers you have them pretty well handled.
