Results 1 to 7 of 7
Thread: pool leak help
    pool leak help
    Ive notice over the past several weeks my pool is losing an inch of water or more per day. Ive tried injecting dye around possible leak points with no luck. The water level seems to drop faster with the pump off but not considerably. The pool stops losing water when the water level drops about an inch below the skimmer mouth opening. Any help would be appreciated.
    19k gallon IG vinyl pool
    Hayward cartridge filter
    Mar 2010
    122
    Re: pool leak help
    Is your pool vinyl liner, fiberglass, gunite?
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    Re: pool leak help
    Its a vinyl liner
    Mar 2010
    122
    Re: pool leak help
    Is this inground or above? Make sure there are no cracks inside the skimmer. When you did the die test, was the pump off? May try that around the skimmer if you haven't.
    Mar 2010
    122
    Re: pool leak help
    If this is a inground pool. What I usually do, is plug the skimmer lines and see if it still leaks. This puts the plumbing out of the question. I guess you could do it with above ground also
    Re: pool leak help
    Thanks for the reply. It is an inground pool. I will try plugging the lines next and post results. There are no visible cracks in the skimmer and the dye test didnt reveal anything leaking in or around the skimmer. Yes i did the dye test with the pump off. I havent ran the pump for several days to see at what level it would stop leaking.
    Re: pool leak help
    Since my last post, i had a leak detection service come out. He pressure tested the plumbing and ruled out any leaks there. Found out i was losing some water thru the pool light conduit. It was sealed off but i was still losing the same amount of water. He came back with some equipment that identifies leaks in vinyl liners. It indicated a leak where the ladder meets the vinyl. I have what i need to patch the vinyl. The problem is i dont see any holes or tears in that area. There is a crease in one particular spot but i dont see a break and dye doesnt seem to suck into the area. Should i just patch over that area anyway and see if the leak stops? If so, do i need to trim that area thats creased? Im not sure the patch would bond unless the surface is flat. Thanks
