Thread: Winter (California Bay Area) - what level CL do you aim for?
    Jun 2012
    Lafayette, Ca / USA
    260
    I won't have to drain or do any sort of formal "CLOSING" of our in ground pool - in fact I just plan to leave off the cover, exposing the water. But curious for those of you in the Bay Area "zone" for winter. What level Chlorine do you aim for during winter when the pool water is in the 50's ? I do note that since the water is no longer (summer) warm, the CL levels stick for a lot longer than when it's mid to upper 80's (water temp).
    Thanks
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Winter (California Bay Area) - what level CL do you aim
    Similar but slightly warmer climate down here. I keep mine where it should be based on CYA level. It's a lot easier to never get algae than to get rid of it. As you've noticed, you don't use a lot of bleach in the winter.
    38,507
    As Richard said, just maintain the chemicals the same way you have all summer ... you will just likely need MUCH less chlorine to do so.
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks All .... will do ...
