Results 1 to 9 of 9
Thread: Large Pool Leak??? I NEED HELP!
    I have an in ground pool that has lost 6-7 inches in one week. I filled the pool back up. Turned off the pumps installed one of those bubble wrap covers and still lost 6-7 inches the next week. I see no exterior cracks or water leaking anywhere. Any help would be appreciated.
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    Re: Large Pool Leak??? I NEED HELP!
    If the circulation is off, the water level should drop to the location of the leak. Have you had any changes in the pool recently that might explain the loss?
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    no recent changes, last spring I had the skimmer replaced.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, mnrland
    I does sound like you have a significant leak. As MiaOKC mentioned, if the leak is more towards the top of the pool, letting it leak down until it stops is a fairly easy way to find a leak, especially if it turns out to stop at the bottom of the skimmer. Also, take a look at this pool school article: http://www.troublefreepool.com/pool-...leak_detection
    Aug 2010
    Dallas, TX
    4,052
    The skimmer is the most common area for a leak.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,425
    Please edit your signature to include information about the pool such as pool type (above ground or in ground), surface (vinyl, plaster, or fiberglass), size in gallons, pump brand and horsepower, filter type (sand, DE, or cartridge), filter brand and size, and any water features, cleaning systems, and if there is a spa (attached or detached).
    This information may help us track down the location of your leak, and adding it to your signature makes it easier to keep track of your information while we narrow things down.
    Love TFP? Become a
    TFP Supporter!
    I found the problem... I let the pool leak down and it finally stopped draining at the level just at the skimmer height. I looked inside the skimmer were it meets the pool and it had a crack at the bottom and both sides. Simple fix with some pool epoxy and no more draining down of the pool.
    Mike
    30,431
    Good work, Mike!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
