Thread: BBB has another perk: Filter Cartridge So Easy to Clean
    Oct 2012
    Houston TX 77064
    101
    I have had my pool on the TFP BBB system now for 2 months, so easy, so clear, so nice.... But noticing a perk to this system with the Filter Cartridges - they are easier to clean, and I don't mean just hosing off, but they are brighter, cleaner, easier to rinse. Has anyone else noticed this or am I just imaging it?
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: BBB has another perk: Filter Cartridge So Easy to Clean
    I do not have cartridges but, since switching to BBB over two years ago, I notice everything is cleaner. The dull film that used to settle on strainers and other PVC areas & fittings before BBB is gone. I also notice the Polaris hoses are lasting longer than before.
    Feb 2013
    Yukon, Oklahoma
    220
    Ellie, while I cannot totally dispute your claim. I will tell you that you may actually be on to something. I dumped the SWG thing last season, and went totally BBB. I did get a couple of new Unicell carts for my setup, and now reflecting on things, my season old carts do look much, much better than last year.
    The reason I can't agree totally is that the pool wasn't used half as much as last year. I keep it covered, but still, the gunk that normally stays in the inside pleats wasn't nearly as bad this year as last.
    Bob E.
    Rick H's Avatar
    Jan 2013
    Liverpool, NY
    45
    I noticed the same thing this past season. I think I only cleaned the cartridge after opening and once during the season. But, I don't think it really needed it, as the pressure only went up a few lbs... The year before I went BBB, I was cleaning the cartridge every 10 days or so. I really believe the difference is as a result of BBB !!!! Another plus!!!
    Upstate/Central New York. Roman style IG fiberglass pool, 13X33, 8800 gallons, installed July 2012. Pentair cartridge filter, 1 hp Pentair single speed pump. Taylor K2006 Test kit. Went BBB route in spring of 2013, no problems, no regrets!!!!!!
    Oct 2012
    Houston TX 77064
    101
    This is awesome - I have more to look forward to. Thank you for the validation!
